Cummins12V98
Aug 07, 2022Explorer III
This is from personal experience with a 11 and 15 RAM DRW.
Leave the rears where they are. Fronts leave the wheels where they are and move the tires side to side keeping the rotation the same.
This is a BIGGIE!!!!!!!!! Get your front end aligned to 1/64" toe. Factory is 1/4" and causes "STEPPING" on the outer edges.
Fronts run 80psi ALL THE TIME!!!
Rears 65 if running full RAWR of 9,750#. Lower weight use the weight/inflation chart for your specific tire size and load range and add 5psi to what the chart says.
Do all the above and you will easily get 60k from quality tires.
EDIT: Lower the rears to 30-35psi unloaded for a better ride and longer tire life.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
