Cummins12V98
Aug 07, 2022Explorer III
time2roll wrote:
I have not rotated tire position in decades. New cars and tires hold alignment so much better and the tires wear flat across the tread with little effort. If there is a wear issue fix the alignment or tire pressure. If the fronts or rears wear faster, replace one axle at a time.
Topic is "How to rotate dually pickup truck tires"
What did you say that helped the OP???
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
