fj12ryder
Aug 07, 2022Explorer III
I got a much better ride with our old dually when the fronts were at 65 psi. Ride was very harsh with 80 psi in the fronts. The new truck seems to ride fine with around 67 psi in all six tires.
I don't rotate tires, just not worth the work to me. But I could probably figure out which tire was off if I got a low tire alert with the factory TPMS. I assume moving the tires isn't the issue so much as knowing where the sensor that just alerted is. If I was a person who wanted to rotate their tires, not knowing which sensor was at what corner wouldn't bother me in the least.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
