Retired_JSO
Aug 07, 2022Explorer II
fj12ryder wrote:Retired JSO wrote:Completely wrong. It may be so for your truck, but don't jump to the conclusion that is so for all dually's. My Ram has the steel wheels and any wheel can be located at any position. YTMV.
You can’t rotate front to rear. The wheels are made for one position either front or rear. I never rotate tires on any vehicle and on my DRW Ford is cost prohibitive since the amount of wear is hardly noticeable. The only way to truly rotate on a DRW truck is to unmount and remount on the appropriate wheel.
The spare is a steel rim that can be run in any position. The front aluminum and the rear aluminum are not the same. Aluminum wheels are usually not polished on the inside.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 22, 2026
