morley
Mar 14, 2021Explorer
SJ-Chris wrote:
I know you are specifically looking for a wired backup camera, but I can't help but throw this out there.....
You can get a wireless backup camera and monitor for ~$150. Since you probably want to mount the camera up high, you likely (right??) have rear upper running lights. You can tap off power from those and mount the camera right under the running lights. Then, to "turn on the camera" from up in the cab, all you need to do is have your running lights on. (Personally, I always drive with the lights on just for extra safety/visibility).
Time to complete the job...less than 1 hour.
-Chris
This is exactly how we did it on our unit also and it works fine, camera just below centre light on the fifth wheel back wired into running light above, on and off with truck running lights. Excellent positioning for rear views, backing up etc.
Only time camera is less effective is if you are backing into the shadows in a site.
With the camera aimed properly we can even see our bike rack on the rear of the trailer while travelling.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
