DrewE
Feb 18, 2021Explorer III
The easiest way is probably to introduce the bleach into the hose, as others have said. That's what I do (and I have a similar setup).
If you have a winterizing suction setup, you could also use that to suck a bleach solution from a container and into the tank. You can similarly use it to suck in potable water, for that matter. Just set the valves to "winterize" and "fill" at the same time.
I think one of the main reasons why some RVs don't have a gravity fill port is that the fresh water tank is located higher off the ground than is convenient for a fill or hose connection. That's the case for my motorhome; the tank is contained in the bed base, and its top is maybe five feet above the ground. If there was a gravity fill port, it would have to be above many people's heads.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 15, 2026
