MEXICOWANDERER
Dec 18, 2017Explorer
Cut and Paste Discussion robbed from another site...
Whether used as a floor or a subfloor, marine plywood resists rotting, warping and shrinking. It resists humidity from steam and can stave off absorbing stagnant water. It even holds up well against boiling water! This makes it a superb option as an underlayment for your kitchen or bathroom floor. At lumberyards, it is usually stored indoors, and this also enhances its moisture-free nature.
Marine plywood is also stronger and more durable than regular plywood, which has only three layers. Marine plywood has five or more layers that are bound together with waterproof adhesive, which allows it to bear heavier loads and repel moisture from its core. As a result, you can use a thinner sheet that will have the strength of a thicker, regular sheet of plywood. In addition, it doesn't have as many voids as regular plywood, which makes it structurally stronger. While regular plywood has little spaces and air pockets in each layer, marine plywood has substantially fewer. The extra strength and durability makes marine plywood a good subfloor for heavy flooring materials, like ceramic tile.
Marine plywood is available in a variety of thicknesses just like regular plywood. However, it is easier to bend and cut. This makes it ideal as a subfloor, since you will doubtless be making many cuts to get it to fit around door jambs, cabinetry, awkward corners, and other tight spaces. Unlike regular plywood, it is usually rated higher, having fewer visual defects like knots. Its surface is smoother and less splintery. It takes paint well and could make a beautiful finish as a top floor—something that regular plywood could not do.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
