Gjac
Dec 20, 2017Explorer III
Fasteners in tension are much weaker than fasteners in shear. I would get a steel T section and drive the center section into the rotted wood then drill from the FG outer skin into the T and install screws. This will provide a bearing surface and carry the bulk of the load. Use your existing holes in the section that fell down to transfer drill though the T section and then screw in place. Good luck on your project, and let us know how you make out.
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jan 16, 2025
