joebedford
Dec 14, 2017Nomad III
How to secure screws in plywood going with grain??
Some of you may recall that we thought we had a broken king pin mount this past summer when we went to Nashville for the eclipse. DW and I stripped off the plastic under the 5th wheel area, inspected and reinstalled. Most of the weight of this plastic is held by right angle brackets on the sides about 1/2" x 1/2". Screws go from below into the plywood behind the fibreglass outer wall - in other words into the layers of plywood not through the layers.
Well, when I got there to Mesa, I noticed that the bracket is pulling away. Obviously the screws didn't bite and hold in the plywood. Probably shouldn't have put them back in the same holes. Duh.
Anyway, is it worth pre-drilling new holes and coating the screws with epoxy before setting them. Or is there a better technique?
As a last resort, I could put SS screws into the side of the bracket and go into the wall cross-grain. That's only going to be 1/4" from the end of the plywood - can't imagine that will hold well.
