Dakota98
Jul 24, 2015Explorer
As above +
First thing to remember is the control panel requires 12 volt in order to operate even if you're on shore power, always keep that in mind.
Things to check for & do at this point are first, make sure the propane tank valve is open & you have propane. Next, light one burner on your stove top & run it for a minute or two. Unless there is another problem of some sort this should solve your issue & the frig should run.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
