MrWizard
Oct 10, 2019Moderator
current in the motor will drop, ONLY if the hot pump has an open circuit
a hot pump 'Stall' with out open circuit, will Increase current drain
and the pump motor will get hotter
unless it has an in motor temp over load AKA 'clik switch'
the ampmeter is the right idea
but better yet is to insulate the fuel lines, especially that big 'tin can' fuel filter
i'm ordering some 'Hot starter' shield wrap to insulate my fuel filter and external fuel pump
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
