AH64ID
Aug 16, 2014Explorer
If the bearing had spun on the spindle there would be deep marks. It's not uncommon to get brown ugly grease on the spindle under the bearing, but that doesn't mean they spun.
I run replaced the bearings/races/seals/grease at all 4 corners this summer and saw some nasty grease on the spindle but there was zero evidence of a bearing spinning on the spindle.
It's still a good idea to start fresh. The OEM bearings are almost always cheap Chinese bearings, and they look like it compared to a nice Timken. If you plan to keep the trailer a while put in good bearings and check them annually.
On a side note, what are you using for wheels/tires? That toy hauler must be putting you over 6,400 on the rear axle, especially with an extra 600lbs of diesel in the bed.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
