AH64ID
Aug 16, 2014Explorer
That's what I plan to do, just treat them like they aren't serviceable.
I am not sure they need to be done yearly, but I will probably pop the rubber boot off a few times a year for a peek in there.
The serviceable bearings on my truck are good for 20-30K miles before repack, there is no reason my trailer bearings can't be the same.
When I was buying my bearings this spring I found out that all Al-Ko 5,200-7,000lb axles use the same bearings, and the inner bearing on the 8K's is the same as well. That tells me that even thou I am at 80% of the axle rating that the springs are the first limiting factor, so the bearings will be fine.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
