RJsfishin
Aug 17, 2014Explorer
Quote:
. I WILL NEVER USE BUDDY BEARINGS OR AXLE GREASE FITTING. REPACK OR STAY HOME. Just my view. Not for anyone else
Well I'm glad you added the last part.
And if you had a boat trailer, you would probably be using them, or else you would spend a lot of money before you would probably learn,.....the expensive way.
Zerk greased axles can work perfectly fine if they are done right.
And to do it right, it takes experience. In reality, if you are experienced to do stuff correctly, you should never have to replace a bearing, or a seal. Enuff said !!
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
