Where do I test to see if truck is charging the fifth wheel batteries? Can I tell at the battery connections? I know I have a controller, but not sure how that is wired in the system. While driving a ...
Check voltage on the truck 7 pin connector while running. No voltage will be a truck issue the Ford dealer can help with. If there is voltage then tow it all to the RV dealer.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
