- GordonThreeExplorerguess its a matter of moving 200lbs of batteries or a 40lb tester :) either way works
- naturistNomad II
GordonThree wrote:
Hygrometer isn't going to read out damage to the plates.
Go to Advance / Autozone and rent their battery load tester. It's just a box with a big resistor and a meter, should be cheap / free with a deposit.
Or better yet, take the batteries to one of those places and ask them to test them. They will put them on a tester and run the test for you for free. Of course, they do this because they want to sell you a new battery, but not being able to do so because the problem is really elsewhere, but they are friendly and helpful none the less. - GordonThreeExplorerHygrometer isn't going to read out damage to the plates.
Go to Advance / Autozone and rent their battery load tester. It's just a box with a big resistor and a meter, should be cheap / free with a deposit. - 2oldmanExplorer IICapt. Obvious might be on to something there.
- donn0128Explorer IIJust like testing a 12 volt battery. A giant resistor, a period of time to apply the load, and a way to read the voltage. Oh thats right, its called a load tester.
- MEXICOWANDERERExplorerInverter load, starter motor engine disabled.
Wluldn't an accurate hydrometer reading work? - 2oldmanExplorer IIOther than an inverter, I can't either.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
