dougrainer
Jan 10, 2015Nomad
hoopers wrote:
Thanks everyone for the great switch ideas. I plan to use the inverter to power only my TV's/DVD and the microwave clock. Don't need much wattage for that and want to keep the installation fairly simple.
So, you are using a INVERTER only? Not a Inverter/Charger? If so, you do NOT need to disconnect the Power Converter. Doug
For those that posted they have a breaker in the breaker panel for the converter. Be advised that almost ALL such breaker and converter hook ups include a 120 wall receptacle also. So, while there is 1 wire connected to the breaker, it is junctioned about 6 inches from the breaker with another feed circuit going to a wall receptacle by a wire nut.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
