joelmyer
Jan 10, 2015Explorer
Everybody has talked about a switch.
What I did, Mark 1 installation was to unplug the converter, run an extension cord to a compartment that opened to the outside. Then plug that into my 1kw generator. Inverter on clips in the battery compartment, shore power cable plugged in to inverter. Frig & Water Heater on gas, microwave & ac off.
Mark 2 installation. I had GFI problems. While chasing those I put all the convenience outlets on one breaker. The hot side of that breaker goes to a dpdt switch near the inverter, then back to the convenience outlets through an normal spst switch near the circuit breaker box so I can kill the inverter output.
Now for dry camping I turn on the inverter and flip the switch. I still put refrig & water heater on gas. Shore power is connected to the 3kw generator so when it's running the power converter, micro and ac are available. I have an appliance extension cord cord plugged into the same outlet as the power converter for the toaster oven or the high wattage thing.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
