bpounds
Nov 15, 2018Nomad
CA Traveler wrote:bpounds wrote:Agreed. My rig came with a charger/inverter volt meter on the remote panel and a idiot light voltmeter and the dash voltmeter displays the chassis battery. None of these are connected at the battery terminals but all are perfect for the salesman.
But if you're using an actual battery monitor like a Trimetric, then I'm not sure why you would have a separate voltage meter at all.
The Trimetric came later and is connected directly to both battery bank posts.
I was thinking trailer, since that's what I have. My bad. I can see the need for a dash voltage meter, plus whatever happens to be back in the coach.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Dec 04, 2017
