rk911
Nov 09, 2019Explorer
ENG2242 wrote:
I have a residential refrigerator with water connection. Suggestions on how to winterize it. I opened up the back panel and could not find any instructions or valves.
Thanks guy’s,
David
should be in your owner's manual but this is how I do it. I'm assuming you use the pink RV anti-freeze.
- empty fresh water tank
- let icemaker run until no ice is produced
- run RV anti-freeze through the coach like you normally would.
- continue to run the ice maker until you see pink slush
- turn off the ice maker. on ours I raise the bail wire.
- power off the fridge.
- I leave the fridge/freezer doors cracked open to reduce mold.
Having RV issues? Connect with others who have been in your shoes.24,391 PostsLatest Activity: Jun 08, 2026
