DutchmenSport
Nov 10, 2019Explorer
If you live in it, and still want to use the "pink stuff", as stated above, then simply turn off the shut-off valve that runs to the refrigerator and disconnect the line running running to the refrigerator and let gravity drain it. Then bleed the water that runs to the shut off valve until it turns pink.
When unwinterizing, run clear water to the shut off valve until there is no more foam or after taste. Once clear, reconnect the line to the shut off valve and and run normally again.
Having RV issues? Connect with others who have been in your shoes.24,391 PostsLatest Activity: Jun 07, 2026
