TheLostBoy
Jul 27, 2017Explorer
red31 wrote:
note the little window at the bottom right that has fuses.
one for each 12v circuit so you can use 1 blue for 1 circuit and the other for something else
Yeah, that PDF almost looks like the one I have (minor differences like button sizes/colour), thank you! I don't think I'll need the other circuit then. I really just want to run my lights and one water pump for the sink.
red31 wrote:
also note it is not suitable for charging.
That's good to know and I think THAT is the cause of the issues I've been having as the batter has previously been connected to the 12v output on the converter. All I need to do now it add some other switches or some way I can put in a battery charger so it doesn't damage anything else.
red31 wrote:
Extra breaker for optional 120vAC circuit. (for a battery charger!!!!)
Why you get 2.8v without power????, was battery hooked up, were you holding your mouth right?
Huh? I don't follow. The second breaker is for a battery charger? How would that hook up?
I got 2.8v when I had one of the blue breaker switches on and one off (didn't matter which one I had turned off) and I got it off of both of the blue wires (using multimeter on the blue and white 12v output wires). Does that make sense?
...Holding my mouth? Not sure what that means? Is that a joke that I missed or should I not be breathing something in?
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 26, 2026
