ymollard's avatar
ymollard
howto remove furnace from motorhome
it seems every time I fix one thing something else goes!
I need to fix the furnace but I cannot even figure out how to remove it.
from the outside all I have is the exhaust vents and on the inside a 12 by 4 inch vent on the floor. if I remove the vent I can see part of the furnace.
the motorhome is a 93 Winnebago Vectra and the furnace a suburban nt34 bw.
any ideas?
thanks
yannick M.
Moved to Tech Issues forum from DIY.
  • Contact Dinosaur Electronic Boards.......LINK
    Then get a Dinosaur Ignitor Board from one of the on-line vendors.
  • Ok, I figured out how to remove the furnace. I had to open the basement doors on each side of the furnace to find 4 screws holding the panel. Anyway I am now looking for a control board for it and I am wondering which I need. The furnace is a suburban nt34 BW. I cannot find any mentions of this model anywhere. I found nt34 sp and other letters but no BW. Does anyone know which board I need?
    thank you again,
    Yannick
  • ymollard wrote:
    I'll check this weekend for some screws to remove the panel, do you mean the whole piece of siding where the small exhaust is screwed in comes off?
    I am working from memory, but if the furnace is in the basement, the siding where the exhaust is opens just like the other basement bay doors- it is just screwed in on the bottom rather than having a latch.
    You do have to remove the exhaust vent first.
  • I like the chainsaw idea!...
    as far as what is wrong with the furnace, the fan comes on but it just blows cold air.
  • What is wrong with the furnace? I just found the following video on blower motor replacement...might help. He also has a number of other helpful videos.
    http://www.youtube.com/watch?v=d7YTOcSPOyI
  • IIRC, the sidewall can be opened just like a bay door- there are screws holding it closed at the bottom.
  • A bigger chain saw.LOL ok you gotta remrmber most the things in a rv were put in before the gooies were put down ,look and see if the floor can be removed in that area couch etc . theres a way just sit and think it out. maybe a panel under the rv.
Having RV issues? Connect with others who have been in your shoes.24,380 PostsLatest Activity: Apr 16, 2026
