wa8yxm
Apr 27, 2022Explorer III
Yes it will work just Fine.. I did that many times no problems
Well one possile issue.. due to the nature of electricity you use Volt-Amps. so if your rig needs say 3500 volt amps and the voltage is 120 volts. NO problem (30 amps at 120 volts is 3600 volt-amps) But if the voltage drops to say 100 volts park side. now it needs 35 amps to get that same 3500 volt-amps and click goes the park breaker.
NOTE it's not watts (Watts are generally less than volt-amps) it's volt-amps.
But we normally speak of them the same.
