wa8yxm
Oct 30, 2021Explorer III
fj12ryder wrote:
I have the 50 amp model, and am very satisfied with it.
Had the 50 amp module.. My rig was wired as follows
Shore power===Hughes==Surge Guard==Auto Transfer Switch.
One park I often parked at (possibly 2) was very nasty low voltage wise.. Never had a low voltage issue (Saw some truly scary voltages at the post though) Hughes fixed 'em.
Do be aware however that volt-amps are volt-amps
If power coming in is 120 volt and you are drawing 25 amps that's 3000 volt amps.
But if the power goes down to 100 volts that means 30 amps needed to hit 3000 VA (Most people think volts * amps = Watts. true in a DC circuit but in AC it's Volts*Amps = Volt Amps VA times Power Factor = Watts.. COnfused me for about 40 years before I figured it out so don't feel bad.. and I have documents saying I know this stuff)
