I was wondering if anyone out there has any experience with the Hughs autoformer. Its suppose to give the voltage a boost if the incoming voltage drops below a specified limit.
If you look at a multi voltage motor, the lower the voltage the higher the amp draw. That is true for an inductive load. For a resistive load like electric water heaters the opposite is true. I know in my coach the largest current draw comes from my a/c units. So I feel I'm doing them a favor by using an autoformer.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
