I was wondering if anyone out there has any experience with the Hughs autoformer. Its suppose to give the voltage a boost if the incoming voltage drops below a specified limit.
The only way I am stealing voltage from other campers is by being there in the first place. If they want higher voltage, either have the campground fix the faulty/overloaded electrical system, or have everyone turn off their ac's. Less load (campground wide) higher voltage, but the higher voltage is useless unless you are using it.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 28, 2026
