USMC46's avatar
USMC46
Humming Noise in Electrical Cable Area
I am hearing a humming noise in the compartment that stores my 50 amp cable and it's reel. I unplugged from shore power and the noise is still there. You can hear it from inside the bedroom. My coach is a 2004 Dutch Star. Any ideas what this is ? Normal ? Thanks.
  • do a search for ATS (automatic Transfer switch) humming, lot of info on the forum about this. possibly your issue.
  • If you have a generator then I'm sure its the transfer switch (gen/shore switch) making a humming noise. Pretty common for some transfer switch models. Sometimes you can take the contact points apart and clean them up to see if that helps (power off obviously) or look for a better model less likely to hum.
  • I had a Dutch Star for a few years, I had similar, It was the Power Converter/charger - that rig has a seperate Inverter/Batt Charger. The Charger was in a compartment under the bedroom slide. The fan was going and making a noise - I replaced the charger.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Fan on converter trying to cool it down, Fan is a 12 volt device.
    Crickets
  • Battery disconnect Switch? Neighbors Jayco has a relay disconnect switch.Needs power to hold it closed. Quite (no power) when off.Should have been a latching relay so power is only needed to make the switch. Don"t know if that is what you are hearing though
  • Possible the Converter Fan is running which will run even after 120 disconnected until the converter cools down. If you have an Inverter/Charger, you will not have a Converter. The standard Converter is in the shore cord Compartment on a Newmar. The optional Inverter is on the Passenger side. On your Newmar in that compartment you have
    The Transfer box
    The Converter/s if you have them, your model may have 2 converters
    The Power Cord reel
    The BIRD control relay(this will not make any noise)
    The Emergency Start solenoid
    The Battery disconnect Solenoid Doug
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
