dougrainer
Jan 05, 2015Nomad
Possible the Converter Fan is running which will run even after 120 disconnected until the converter cools down. If you have an Inverter/Charger, you will not have a Converter. The standard Converter is in the shore cord Compartment on a Newmar. The optional Inverter is on the Passenger side. On your Newmar in that compartment you have
The Transfer box
The Converter/s if you have them, your model may have 2 converters
The Power Cord reel
The BIRD control relay(this will not make any noise)
The Emergency Start solenoid
The Battery disconnect Solenoid Doug
The Transfer box
The Power Cord reel
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
