parkermd00's avatar
parkermd00
HWH Computerized Leveling System Issue
I purchased a used 2017 Winnebago View with an HWH computerized hydraulic leveling system. I've only owned it for about 6 weeks and the system worked normally when I purchased it, but started an issue after a couple days and about 500 miles of driving.
When I start the engine, everything is normal, green "travel mode" and various yellow lights for the low side. As soon as I set the parking brake, without doing anything else, the pump begins to run continuously. No individual jack down lights. If I push the auto-level or auto-store buttons, the blue lights flash a couple times, then the "excess slope" light comes on and the panel becomes completely unresponsive while the pump continues to run continuously. No jacks move.
Frequently while driving, the "jacks down" light and buzzer come on. I stop to check the jacks and never has there actually been a jack down. When I pull over, same scenario, I pull the parking brake and the pump begins to run continuously. In these cases I have pull off the control panel to science the warnings.
In the past couple of weeks, the problem was intermittent. After the coach sat overnight, the system would work normally the following morning. Now the problem is continuous and I haven't been able to get the system to work our last couple of overnights.
Not much in the manual or on the website from what I can tell. HWH says they will call me back in 3 weeks. My local RV shop is booked for the next 8 weeks. Any thoughts? Any obvious things to check?
Having RV issues? Connect with others who have been in your shoes.24,341 PostsLatest Activity: Dec 07, 2025
