dougrainer
Sep 27, 2015Nomad
1. You are extremely lucky you do not have leaky solenoids. NEVER swap HWH solenoids without having replacement o rings. They usually leak when removing they get nicked.
2. You NEVER have to swap solenoids to check for HWH problems. If you manually release them and they operate, then you check to see if you have 12 volt power to them when operating. ODDS are you have a fuse blown for those solenoids. EACH solenoid has its own 10/15 amp ATC fuse. Find the control box for your system and the fuses will be there. Doug
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
