23mikey
Oct 27, 2016Explorer
jharrell wrote:
My Magnum 3000 Hybrid supplies the entire coach as I did no sub-panel for it. However I have only 30amp service and 1 A/C and I still needed to get a Micro-Air Easystart on the A/C to keep the Magnum from complaining about the 70amp start current on the compressor.
I like having the whole coach run off the inverter, solar or alternator helps run the A/C using Load Support VDC if I want and the shore amps setting is for the whole thing.
With a 50amp coach I would do a sub-panel and pick which loads it ran.
X2....This is how I wired my 5er and it works great. Load shedding (control) is the responsibility of the user.
Safe Travels!
Mike
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
