bartiee's avatar
bartiee
hydraulic slide opens premature
when slide has been closed for about a week,it opens a little by itself. Any support?
  • When operating the hydraulic slides pressure build. When you stop movement pressure remains between the pump and valve or cylinder. I find to relieve the latent pressure I can cycle the selector valves on the other slides and I can hear the pressure dump back to tank. Does that make sense?
  • Valve leaking allowing the pressure to bleed off. Do you have selector valves? If so, cycle them a couple of times and see what happens.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 12, 2026
