Chris_Bryant
Nov 05, 2016Explorer II
Umm- the Xantrex most certainly does do load support - http://xantrex.com/power-products/inverter-chargers/freedom-sw-12v_newgen.aspx
You can also stack units for higher output or tie them together to get 240 volt power.
Xantrex wrote:
The second generation 2000 watt model has been completely redesigned to include many of the same great features found in its high power counterpart.A key feature enhancement is ‘Generator Support Mode’ which enables the Freedom SW to supplement a generator¹ when AC loads exceed the generator’s capacity. The new generation models also feature improved AC transfer/AC input detection time, providing the ability to transfer AC loads to batteries in less than 10 milliseconds when the incoming grid or generator power is lost. Connected loads are almost unable to feel the power transition due to this quick transfer time.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
