pianotuna
Nov 05, 2016Nomad III
4 to 24 amps. Does that mean the "generator support" is limited to a maximum of just 288 watts? Heck, the Yamaha 3000 sIEB generator does 500 watts for ten seconds.
By the way, be aware that "load support" is NOT voltage support, at least on the Magnum line.
jharrell wrote:
Looks like according to the manual its only enabled if you have the AGS module, it seems to say however it will work with any power source. It has a 4-24a range for gen amps.
So it seems similar to Magnums Load Support AAC but requires an AGS, it doesn't seem to have a Load Support VDC mode.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
