jharrell
Nov 05, 2016Explorer
pianotuna wrote:
4 to 24 amps. Does that mean the "generator support" is limited to a maximum of just 288 watts? Heck, the Yamaha 3000 sIEB generator does 500 watts for ten seconds.
By the way, be aware that "load support" is NOT voltage support, at least on the Magnum line.
4-24 is the "shore max" or "max input amps" setting in the Magnum depending on remote, except the Magnum is 5-60 amps.
Yeh I don't think any do "voltage boost" must be something inherent to design, it can add current but not increase voltage. Have to get a autoformer to boost voltage or go full double conversion Charger->Battery->Inverter.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
