theoldwizard1
Nov 06, 2016Explorer II
brulaz wrote:Searching_Ut wrote:
Since I'll probably go with the old dependable wet cell batteries I realize my high demand loads will have to be kept short.
As others have said, voltage sag with 4 wet-cell GC2s might be a problem at high starting loads. You might have better luck with 4 AGMs, ...
WOW !!! That is a pretty "broad brush" statement !
From my "non-expert" knowledge, there is NOTHING in an AGM battery design that makes is battery at handling high starting loads.
A quick, simple, but crude way of comparing battery A to battery B (assuming they are both deep discharge batteries)[/] is simply look at the weight. More weight means more lead means it is capable of storing more power.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
