theoldwizard1
Nov 06, 2016Explorer II
westend wrote:theoldwizard1 wrote:
Not "hybrid" but worth watching the following video, especially the last 5-10 minutes.
Off Grid Solar Powered RV Air Conditioning – Is it Possible?
That's kind of a demonstration. It's too bad that the Wynns are technically challenged. Yes, they proved that their AC can be run off the inverter but there is no mention of how this might effect their overall use.
Not disagreeing with you, but did you watch the last 5-10 minutes ?
Check their blog Off Grid Solar Powered RV Air Conditioning. This blog post has a links to what the various manufactures reported back to them with. Probably one of the big things is a "soft start" AC kit.
Searching_Ut wrote:
I think I'll wait till spring to decide for sure, but now I'm leaning more to just going simple, 4x6 golf cart batts, 10 x 100 watt flat mount solar panels on the roof in two banks with all panels effectively in parallel, twin bogart SC2030 controllers.
Sounds reasonable. I would strongly suggest you find a distributor for Trojan T105 batteries. A bit larger, but they hold a lot more power than a GC2.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 03, 2026
