Searching_Ut's avatar
Searching_Ut
Hyrbrid Inverter and generator to run AC?
I’m looking for inputs from those using hybrid inverters, especially in conjunction with generators to run high load devices like the AC. I currently have 600 watts of solar on the roof of my 5er, with a samlex pure sine inverter powering the whole rig AC wise. The inverter is wired through an auto transfer switch, and I put in an isolation relay to automatically turn off the Intellipower DC converter when the Inverter is switched on, but all other power management we do manually. (Fridge and Hot water to Gas, AC Off etc.)
I’m going to put more solar on the roof taking the system up to 1000 watts, and the plan for when I retire next year is to replace the current 3 group 24 batteries to 4 6 volt jars. I’m not sure what I want to do inverter wise at this time though. I’m thinking of going to a 2000 watt hybrid, such as the Xantrex freedom SW2012 12V 2000W. Besides allowing the wife to potentially use her hair dryer for short periods without my having to go out and fire up on of the 2 champion 2000 watt inverter generators we have, and maybe even some microwave popcorn in the evening. Currently I have to run both generators in parallel to run one of my 15k AC units. Would I be able to get away with just one generator being used, with the xantrex taking care of the compressor starting surge, and using the solar/batteries to fill in the generator output deficit? Looks good on paper, but I’d love to hear from folks actually making it work, if in fact it is working for them.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 09, 2026
