RJsfishin wrote:
Quote:
Then if I am happy I will have to find more mad money so I can install the last two panels that I want. I am aiming for 600 Watt system.
If you already outta money before the last 2 panels, you really gonna be outta money after you get 4 more batteries, and the 3,000 watt inverter, and all the other stuff that goes w/ a whole house system ! :)
I have the batteries already. Have two banks, bank #1 is 4 X GC2 about 210 amp each, and bank #2 is about and 370 amps. I have been using only one bank, saving the other bank if I run the main down to far and I was in a no run time for the generator. but that issues should be over with now. So far I have only been using two 300 watt inverter. But you never know I may just end up getting a bigger inverter after I see how good solar power is.
Will post more on my results after it is all up, adjusted and running. When I have some good number to work with. Thanks everyone that has helped me with my research in the past. Gary
