MEXICOWANDERER's avatar
Mar 06, 2014
I DAMAGED MY RIBS READING THIS (Chinese Instructions)
This charger can charge ??various hydro bottles, dry batteries, maintenance-free batteries, lead-acid batteries of 12V 24V 6AH-100AH, not below 6AH. When charging the battery or small capacity motorcycle batteries, because the battery capacity is small, internal resistance, there will be no bright lights, the lights role is to show the charge state, charge a small capacity battery, bright lights, with LED LCD charging status, and therefore does not affect the use.
Charging operation
Step 1: Check the rated voltage of the battery to be charged and the charger output voltage match.
Step 2: Connect the charger and charge the battery as required to be properly connected.
Step 3: Check the mains voltage and charger rated input voltage matches.
Step 4: connect to mains and connect the battery, observe the indicator light, charging cooling fan is working.
Step 5: If the charger does not work, dashing off the mains and check the mains, battery and all the connections.
Multiple protection
Overheat protection: When the temperature exceeds 105 ? charger when the charger turns off, then no current output, when the temperature drops about 80 ?, or turn off after ten minutes to restore power to continue to be used.
Short circuit protection: When the charger output accidental short circuit automatically turns off the charger output and beep alarm, excluding short-circuit, the connection is automatically restored after properly charging.
Reverse Polarity Protection: When the charger output positive and negative contrast with the storage time, the charger will automatically turn off the output and beep alarm will automatically resume charging the correct polarity connection.
Low-voltage protection: When the battery voltage is lower than 1.5V single cell charger protection does not start, and will beep alarm. Avoid Battery charger voltage does not match the damage to the device.
Switching power supply charger can achieve constant voltage constant current stoped and other control means when the input voltage is constant within a certain range of the output voltage within a certain value (as well as by the constant current control), constant refers to the entire charging process the current does not exceed the value of the set, batteries and chargers protective role in the trickle charging is complete after floating charge state. Raise rates and reduce battery powered cell loss rate, charge the battery completely prevent hot filling drums. Temperature compensation of the charging voltage to maintain adequate winter, but in summer the charge. Because it is pulse charging, the battery has some repair. Than older cattle ring core, silicon charger work efficiency saving thirty percent!
Simple failure investigation :
Battery charger for charging time is only a few minutes , or even less time , has been shown to full power status .
1: Check if the charger because of overcurrent, overtemperature protection or low voltage protection ( presence does not match the voltage ) to observe the cooling fan is working properly .
2: Description Battery has no capacity or the original full power ( recommended to be re-tested after discharge , or choose another shortage of battery tests )
3: It is recommended to try to add supplemental battery solution or distilled water.
4: Check the clip and the battery charger output column contact is good .
To charge the battery or the charger when the battery casing fever still does not display full time job .
1: Check the battery if there is a short circuit , leading to the charging voltage can not reach a long-term voltage setting of the charger.
2: battery leakage phenomenon already exists ? 0.3A current.
3: battery production processes, materials failure, suggested the use of genuine battery .
4: Replace the good battery and retest.
When the charger is connected in the normal beep when there is an alarm or does not work .
1: Check the battery voltage is serious loss of electricity , resulting in the charger and low voltage protection ( presence does not match the voltage ) .
2: Battery shelved indefinitely so dilapidated ( belonging scrap batteries ) or internal resistance , serious short-circuit the battery .
3: Connect the power -load state is still beeping alarm.
4: It is recommended to replace the good battery retest.
Warning:
1. Charger has a high-pressure, danger, if a failure occurs, please contact the manufacturer;
2. Prohibited in wet, high temperature, flammable, combustible gases environments;
3. Non-blocking machine cooling vents or fan stopped using;
4. Non-stormwater into the machine to avoid damage;
5. Prohibited non-professionals to open or modify the machine, or peril.
Tips
In order to better maintain your battery, please do not let the battery when the battery charge is depleted capacity of lead-acid batteries are not suitable for handling memory battery charge and discharge ground, if the battery capacity is depleted 12V (10V or less), first battery is great harm, and we will follow because the charger while prone overcurrent protection, then the user can continue to use the power to be shut down for ten minutes, then explain your battery is less than 10V, the serious loss of power state. Please next time you use the battery must pay attention!
Charging encountered questions :
1. When charging , the power plug ( do not take the battery clip ) and the charger indicator is flashing red and green . When the clip according to Red + Black - after receiving the battery , then the light will turn red , while the fan starts to rotate , then start charging the
2. To charge the battery voltage is below 9V , charger indicator remains will be displayed in green. Do not turn red , it means not charging.
3. When charging , the light has been green. What is the reason?
May charge your battery is full , it will not change a red light .
4. lights flashing when charging
You may reverse the positive and negative . Disconnect the battery clip to reconnect.
5. Plug in the power , connect the battery when the two clips , battery charger indicator changes from red to green quickly , then state your battery power is full, then you can continue to add more effect 3-5 hours Jia .
6. When charging , the battery will hear carefully inside "grunt " ( similar to the boiling water to a boil ) sounds, this is normal , indicating that is charging.
7. When charging, the charger will generate heat, which is normal, electrical work , heat is normal.
8. Charged up a long but has a red light , indicating possible that your battery has been broken , electricity can not be stored , it has been charging state. Make sure your battery is bad.
  • Even if I stayed at a Chinese Holiday Inn Express could I ever decipher that.
  • When wiring up a trailer battery bank, should I connect my various hydro bottles in series, parallel or some quantum state between those two choices?
  • Other than being quite "wordy" I don't have a problem with it. They did a lot better than I could do in writing it in Chinese.
  • Real campers just toss out the instructions.
    Never would have seen it.
    BTW, hydro bottles = jars (and plenty around here use that term)
  • wnjj's avatar
    wnjj
    Explorer II
    I'm just glad this silicon charger has made those older cattle ring core ones obsolete!
  • have a model tank with Kithium Ion battaries. Says charge full. Doesn't
    say how long, and there's no indicator light. Does say not to charge long. Fire get away.
    One should read the instructions, only, as a last resort. Reading instructions, is like stopping to ask directions. Ya Just Don't Do That.
  • "Turn upcoming 1.63 miles"
    "Destination 88 yards on right"
    If someone detonates an EMP weapon in the upper atmosphere, 250 million people are going to die because they are going to get lost between home and the supermarket.
    Oh yeah, I Simichrome polished my 50 year old slide rule a few months ago.
    Ever see a Chinese keyboard? 4,000 characters? For real they used to use a chair on rails to slide up and down a row full of keys. Read right to left. Twist their twist ties counter-clockwise to close. Boy their cellular text keyboards must be something - carry around in a back pack.
    DOES THIS MEAN "THIS SIDE UP"?
    Looks like a periodic table of the elements. Hydrogen would be at the top left.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
