D.E.Bishop wrote:
I mentioned in a post about Deltran Solar Battery Tenders that I was having a problem with my chassis battery dying and received several well meaning and in other circumstances helpful suggestions.
What I found astounded me, in short, I had to disconnect the power from my temp/Compass device and didn't connect my battery dying with that.  When I was able to close up the dash, I hooked the device up and did not notice that the device wasn't working.  Turns out that the four wire plug that came with the device is keyed with not one but twp "D" shaped covers over the connectors, one on each side.  In makes ir hard to plug them in any way but with D shaped plug contacts to the outside D shaped sockets other than correctly or and this is where I'm befuddled 180 and eighty degrees out of alignment.
That put the 12vdc directly from the battery to the ground of the circuit board.  While some components are kaput, some made a high resistance path to ground.
Replaced the Direction/Temp main unit and now it works great and no parasitic drains.
Four hours and a $270.00 replacement part later I can tell where I'm going and how hot it is.
I don't know if its just me and my feable mind but this entire post makes no sense to me.
