Muddydogs
Aug 26, 2015Explorer
MiPaJacks wrote:
Guys, I know not to play in your sandbox. My skill set is far below yours.
I have a 97 Holiday Rambler Vacationer with two 6 volt off the shelf batteries, It has the original not-smart charger, I think I can do better, therefore I read with interest Mex's sticky (to be) and his informative post on battery charging.
I followed the various posts on 8/18 and figured I could create a better charger based on your collective knowledge.
As listed by Ninerbikes in a post on 8/18 I ordered:
Megawatts 36 Amp supply
Watt Meter fron China 60W 100A
Mex's intermatic Timer 4 hr.
Jumper cables (cut off one end)
I learned from Landryacht today to use Power Poles to connect the various cable (Thanks Landy)
I have spent many years reading and educating myself on here, I know the pecking order.
Thanks for everyone's help
James
Are you going to be moving your meter around or is it dedicated to this power supply? I ask because if you don't plan on using the meter for anything else but this charger I would forgo the Power Poles and just hardwire the parts together. Power Poles are great and I use them for my Ham radio that gets moved from house to truck but wouldn't waste the money on them if I didn't need to move things. A simple butt connector for $2.00 a ten pack will take care of your connections.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
