landyacht318
Aug 26, 2015Explorer
How do you intend to use the megawatt?
Are you charging by generator?
Is recharge time a factor?
Do you intend to use in in concerto with whatever converter came installed in your RV?
Do you know which converter it is?
Will you be removing the batteries in winter and charging them at home?
The powerpoles are a great connector, but whether you even need any removable connector is in doubt.
Alligator clamps are not an Ideal connection, not for anything long term.
The watt meter leads being 12awg and aluminum are hardly ideal.
Off the shelf 6v battery could mean a 6v starter battery for a vehicle made in 1952, or a benchmark trojan t-105 golf cart battery, or anything in between. Which battery brand?
Please Ignore posts from those who seek confrontation, and we can help you get the megawatt set up in a method most beneficial to your uses, but we need more information as to your intentions as to how you wish to employ the power supply.
Having RV issues? Connect with others who have been in your shoes.24,399 PostsLatest Activity: Jul 13, 2026
