MiPaJacks's avatar
MiPaJacks
I followed your suggestion and bought the whole thing
I ordered the Megawatt, meter, jumper cable, I assume they go in a line, but how do you attach the cables together? I may understand how to do it when I get all the parts.
I will never know as much as the resident gurues have forgot, so I will try to just tag along and not get in the way!
Thanks
James
  • Volt, amp meter goes in your 12 volt line. depending on line length you could connect the meter to the megawatt 12 volt output then chop the ends off one side of the jumper cables and hook them to the other side of the meter. MexicoWanderer did recommend tying into all 3 12 volt outputs on the megawatt instead of using just 1. I assume this is to get a move even power and reduce heat.
