- MuddydogsExplorerVolt, amp meter goes in your 12 volt line. depending on line length you could connect the meter to the megawatt 12 volt output then chop the ends off one side of the jumper cables and hook them to the other side of the meter. MexicoWanderer did recommend tying into all 3 12 volt outputs on the megawatt instead of using just 1. I assume this is to get a move even power and reduce heat.
Having RV issues? Connect with others who have been in your shoes.24,319 PostsLatest Activity: Sep 18, 2025
