Dutch_12078
Oct 15, 2018Explorer III
BFL13 wrote:
There is also the difference between the stranded type with the thicker wire strands, and the type with a kabillion silky thin strands.
Can't say which has which, but they have cords that are especially flexible in freezing temps. I find the silky ones are very hard to use in a set-screw terminal, as they keep pulling out. Need much "strain relief".
I think one type is for "welding" wire, but I have no idea why.
Good topic! Should learn something I think.
The more strands in a given size wire the more flexible it is. The wire with hundreds of very fine wire is often called "welding cable" because that application typically calls for a high degree of flexibility so the welder can more easily manipulate the welding tools. The fact remains though that a 10 AWG wire will have exactly the same total metal cross sectional area and total circumference whether there's one strand or a thousand. The physical diameter of the multi-strand wire will be a bit larger than the single strand due to the air spaces between the strands, but both will have exactly the same 30 amp ampacity rating.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
