time2roll
Oct 16, 2018Nomad
wanderingbob wrote:Yes it will work. Although a repair tech could be misled to think romex is 120vac and reconnect to higher voltage.
The reason that I was curious was because I need to run a 20 amp , 12 volt circuit about 15 feet and I have some 12 ga romex , sounds like that might work !
thank ya'll
I would use more customary primary wire for 12 volts.
http://www.genuinedealz.com/marine-wire/marine-primary-wire
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
