SoundGuy
Sep 13, 2016Explorer
SoundGuy wrote:
It's called "choice".
mike-s wrote:
Very good, you learned a new word. Now learn what "suggestion" means.
Now that's an intelligent response that adds to the conversation. :S
To the OP ...
Any Keurig branded coffee maker I've looked at requires ~ 1500 watts, even the smallest K15, so perhaps that Mr Coffee Keurig which hedge mentioned works for him with a Can Tire 1000 watt inverter might be a good solution for you. As I already mentioned I can successfully brew coffee with my 550 watt Cuisinart, even run a 650 watt toaster with just a single G27 powering the inverter, but any more draw and the inverter alarm will sound. Four GC-2s is probably unnecessary if you can limit your inverter size to 1000 watts and is the reason I'd consider just two GC-2s or two G31s as a sufficient upgrade from my current single G27. :)
