Boon_Docker
Oct 14, 2021Explorer III
albow wrote:trailrider wrote:Well, that didn't work. It sure gripped but I couldn't turn it. I'm going to get my stronger neighbor to give it a go and then try something else. I wonder if it's because it's nylon and the sprinkler heads are maybe pvc?
Go to the hardware store and buy a "sprinkler riser removal tool." I have removed several with one of these, works perfect.
https://www.homedepot.com/p/1-2-in-and-3-4-in-Plastic-Nipple-Extractor-26076/100203404
With a tool like that you are expanding the plug making it even tighter.
Heat up a screwdriver and melt a couple groves (top and bottom) in the plug right down to the metal water heater threads.
Then take the screwdriver (once cooled), place it between the plug and the water heater thread and pry the plug out.
Having RV issues? Connect with others who have been in your shoes.24,404 PostsLatest Activity: Aug 08, 2026
